We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The improved Slim N17 Serialised Combination Laptop Lock for Wedge-Shaped Slots 25-Pack delivers increased strength in a smaller size. It's the strongest keyless locking solution for laptops and tablets with a wedge-shaped lock slot, independently verified and tested for industry-leading standards in torque/pull, foreign implements, lock lifecycle, corrosion and other environmental conditions. The Slim N17 Serialised Combination Laptop Lock for Wedge-Shaped Slots 25-Pack features a stronger cable with greater pull strength, an updated slider for easy one-handed engagement of the lock, and a pre-programmed 4-number code so you can immediately put it to work without having to set the combination yourself. A serial number is etched onto the lock, making it easy to verify and retrieve a lost or forgotten combination.
Product Description | Kensington N17 Serialized Combination Cable Lock for Dell Devices with Wedge Slots - 25 Pack - security cable lock | Product Type | Security cable lock | Packaged Quantity | 25 (specifications are for single item) | Product Material | Carbon steel | Features | Combination lock, tamper-proof, cut-resistant, wedge lock slot | Localisation | Europe |
General | |
Miscellaneous | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
