Kensington Orbit Trackball with Scroll Ring - Trackball - opt...
Kensington Orbit Trackball with Scroll Ring - Trackball - optical - wired - USB
£36.37
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ambidextrous design works equally well for both right-handed and left-handed users
  • Compatible with Windows 8
  • Award-winning Scroll Ring lets you scan up and down pages with ease
  • Detachable wrist rest supports hand and wrist for ergonomic comfort
  • Optical tracking technology for superior cursor control and accuracy
  • Medium 40mm ball is designed as a perfect sphere to provide exceptional precision
  • PC and Mac compatible
  • Plug & Play installation via wired USB connection
  • TrackballWorks software lets you customize the 2 buttons, adjust cursor and scrolling speed
  • Recommended Use: Leisure
  • Type: Trackball
  • Wired / Wireless: Wired
  • Colour: Black
  • Compatibility: Mac, PC
Product codes
Kensington TrackballWorks
idea: Your trackball, your rules.
Download Kensington TrackballWorks software to customise the functions of each of the buttons found on this Kensington trackball. The result is a more productive and truly personalized computing experience. Set your preferred functions or keyboard shortcuts for each trackball button or combination of buttons, adjust the pointer speed and acceleration and do so much more. Best of all, by allowing you to personalise your trackball experience, TrackballWorks makes your trackball work the way you do. TrackballWorks is compatible with the latest operating system versions including Windows 7, Windows Vista , Windows XP and Mac OS.
Product Description Kensington Orbit - trackball - USB
Device Type Trackball
Connectivity Technology Wired - USB
Orientation Right and left-handed
Localisation Europe
Movement Detection Technology Optical
Features Scroll ring
Cables Included 1 x USB cable - integrated
OS Required Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Orbit Track...
£36.37
