Kensington Orbit Wireless Mobile Trackball
£54.94
Delivery:
Standard: 1-3 working days
Key features
  • Ambidextrous design for right-handed or left-handed users
  • Compatible with Windows 8
  • Compatible with Windows 7, Windows XP, Windows Vista , and Mac OS X
  • On/Off switch helps prevent accidental battery drain
  • Plug & Play installation
  • Plug and play with no drivers needed
  • Type: Mouse
  • Wired / Wireless: Wireless
  • Colour: Graphite, Ruby Red
  • Compatibility: Mac, PC
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £58.43
Save £1.50
Offering a precise, compact and versatile experience, the Orbit Wireless Mobile Trackball has everything mobile professionals need for comfort and productivity. It offers better ergonomics, with less wrist and hand movement that will ease the pain of repetitive-stress injuries. With no cables to tie you down, the 2.4 GHz wireless nano receiver works with either Windows or Mac when youre at home, on the road or in the office. Unique touch scrolling, along with the compact 32mm ball, lets you glide effortlessly through web pages and documents, and the nano receiver can be stored right inside the trackball.
Product Description Kensington Advance Fit Wireless Mobile Trackball - trackball - 2.4 GHz - graphite, Ruby Red
Device Type Trackball
Connectivity Technology Wireless - 2.4 GHz
Colour Graphite, Ruby Red
Orientation Right and left-handed
Dimensions (WxDxH) 8.6 cm x 10.8 cm x 3.4 cm
Weight 180 g
Localisation Europe
Wireless Receiver USB wireless receiver
Movement Detection Technology Laser
Buttons Qty 2
Battery 2 x AA type
OS Required Apple MacOS X, Microsoft Windows Vista / XP / 7
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Orbit Wirel...
£54.94
