Kensington Portable MicroSaver2.0 Lock
£41.82
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Strong 10mm lock head offers uncompromised security for even the thinnest laptops and devices
  • Patented Hidden Pin Technology provides anti-pick features unique to Kensington
  • T-Bar Locking Technology attaches to the Kensington Security Slot found on most laptops and other devices
  • Self-coiling carbon steel cable stretches up to 6 feet or shrinks down to 3 inches for easy packing
  • Pivot and rotate ball joint provides superior laptop engagement
  • Independently verified and tested for industry-leading standards in torque/pull, foreign implements, lock lifecycle, corrosion, key strength and other environmental conditions
Product codes
The MicroSaver 2.0 represents the next generation of laptop security with a self-coiling cable that makes it ideal for highly mobile professionals. The MicroSaver 2.0 was developed using strict specifications and advanced technologies.
Product Description Kensington MicroSaver 2.0 Portable Keyed Laptop Lock - security cable
Product Type Security cable
Package Content Cable lock
Product Material Carbon steel
Dimensions (WxDxH) 0.35 cm x 185 cm x 0.35 cm
Weight 90 g
Features T- bar lock, pivot adjustment, hidden pin, rotatable, kensington security slot
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£41.82
