Kensington Presenter Expert Red Laser
£52.81
Delivery:
Standard: 1-3 working days
Key features
  • Backlit button controls move slides forward/back, black out screen and activate the red laser pointer
  • Comfortable grip with special contours for the hand
  • Compatible with Windows 10, 8.1, 8, 7 and Mac OS X
  • Extended 150-foot wireless range to roam the room
  • Cursor control joystick lets you use the presenter like a mouse, moving cursor up/down and left/right.
  • Internal storage for wireless USB receiver so it won't get lost
  • Plug & Play 2.4GHz USB wireless connection
  • Red laser pointer
  • Stock Status: In Stock
Product codes
Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter with Red Laser Pointer & Cursor Control. Sometimes pointing just isnt enough. With a simple flick of a switch, you toggle between presentation and cursor control modes. The wireless 2.4GHz receiver stores conveniently inside the remote, and since its uniquely paired, you dont have to worry about device interference.
Product Description Kensington Presenter Expert Red Laser with Cursor Control presentation remote control - black
Device Type Presentation remote control
Enclosure Colour Black
Localisation Europe
Connectivity Technology Radio
Max Operating Distance 50 m
Battery Pointing device battery
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Presenter E...
£52.81
