Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter with Red Laser Pointer & Cursor Control. Sometimes pointing just isnt enough. With a simple flick of a switch, you toggle between presentation and cursor control modes. The wireless 2.4GHz receiver stores conveniently inside the remote, and since its uniquely paired, you dont have to worry about device interference.
Product Description | Kensington Presenter Expert Red Laser with Cursor Control presentation remote control - black | Device Type | Presentation remote control | Enclosure Colour | Black | Localisation | Europe | Connectivity Technology | Radio | Max Operating Distance | 50 m | Battery | Pointing device battery |
General | |
Features | Low battery alert, built-in laser pointer, back-lit buttons, power on/off |
System Requirements | |
Operating System | Apple Mac OS, MS Windows 7, Windows 8 |
Miscellaneous | |
Included Accessories | Carrying pouch |
Power | |
