Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
Product Description | Kensington display privacy filter - 23.8" wide | Product Type | Display privacy filter - 2-way | Installation Type | Removable | Colour | Black | Display Screen Size Compatibility | 23.8" wide | Product Material | PET film (3H) | Dimensions (WxDxH) | 52.7 cm x 0.039 cm x 29.6 cm | Weight | 70 g | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Display privacy filter |
Dimensions (WxDxH) | 52.7 cm - 0.039 cm - 29.6 cm |
Weight | 70 g |
Shipping Dimensions (WxDxH) / Weight | 35 cm x 0.5 cm x 59.5 cm / 370 g |
Colour | Black |
Display Filter | |
Privacy Protection | 2-way |
Aspect Ratio | 16:9 |
Miscellaneous | |
Features | Anti-glare, fingerprint-resistant coating, 3H hard-coating, 30° visible angle, blue light reduction |
Compliant Standards | RoHS, REACH |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
