Protect the sensitive information on your monitor with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
Product Description | Kensington display privacy filter - 25" | Product Type | Display privacy filter - 2-way | Installation Type | Removable | Display Screen Size Compatibility | 25" | Dimensions (WxDxH) | 55.4 cm x 0.039 cm x 31.2 cm | Weight | 80 g |
General | |
Product Type | Display privacy filter |
Dimensions (WxDxH) | 55.4 cm - 0.039 cm - 31.2 cm |
Weight | 80 g |
Shipping Dimensions (WxDxH) / Weight | 44 cm x 0.5 cm x 72.5 cm / 500 g |
Display Filter | |
Privacy Protection | 2-way |
Aspect Ratio | 16:9 |
Miscellaneous | |
Features | 3H hard-coating |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
