Kensington privacy filters remove the risk of unwittingly sharing your confidential data with an unwanted viewer. A laptop privacy screen keeps you working without needing to adjust in awkward and uncomfortable positions in order to shield your screen from prying eyes.
Product Description | Kensington display privacy filter - 24" | Product Type | Display privacy filter - 2-way | Installation Type | Removable | Display Screen Size Compatibility | 24" | Dimensions (WxDxH) | 51.9 cm x 0.039 cm x 32.5 cm | Weight | 80 g |
General | |
Product Type | Display privacy filter |
Dimensions (WxDxH) | 51.9 cm - 0.039 cm - 32.5 cm |
Weight | 80 g |
Shipping Dimensions (WxDxH) / Weight | 35 cm x 0.5 cm x 59.5 cm / 380 g |
Display Filter | |
Privacy Protection | 2-way |
Aspect Ratio | 16:10 |
Miscellaneous | |
Features | 3H hard-coating |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
