The features that matter most in your office are comfort and reliability. And the Kensington Pro Fit 2.4 GHz Wireless Full-Size Mouse delivers with plenty of both. The full-sized right-handed design feels great in the hand while the 2.4GHz wireless technology is ideal for crowded office environments.
Product Description | Kensington Pro Fit Full-Size - mouse - 2.4 GHz - black | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Black | Orientation | Right-handed | Localisation | Europe | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Movement Resolution | 1200 dpi | Features | Scrolling wheel, soft rubber grip | Battery | 2 x AA type | OS Required | Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista / XP |
General | |
Colour | Black |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | Plug and Play |
Battery | |
Type | AA type |
Installed Qty | 2 |
Software / System Requirements | |
