Kensington Pro Fit Full Sized Wireless Mouse
£23.25
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Adjustable dpi settings for smooth cursor control and precise tracking (800, 1200, 1600 dpi)
  • Clickable scroll wheel is ideal for speeding through documents
  • Dedicated, thumb controlled, back and forward web browser navigation reduces time required to complete web browser tasks
  • Ergonomic design matches natural hand curvature maximising comfort during prolonged use
  • High definition optical sensor delivers smooth cursor control and precise tracking
  • PC and Mac compatible
  • Reliable Plug & Play operation with USB connection
  • Requires 2 x AA batteries (included)
  • Sculpted side panels with soft rubber panels and contoured buttons maintain comfort and grip
  • Professional black and blue corporate finish complements Pro Fit keyboards
  • Type: Mouse
  • Wired / Wireless: Wireless
  • Colour: Black
  • Compatibility: Mac, PC
  • Stock Status: In Stock
Product codes
The features that matter most in your office are comfort and reliability. And the Kensington Pro Fit 2.4 GHz Wireless Full-Size Mouse delivers with plenty of both. The full-sized right-handed design feels great in the hand while the 2.4GHz wireless technology is ideal for crowded office environments.
Product Description Kensington Pro Fit Full-Size - mouse - 2.4 GHz - black
Device Type Mouse
Connectivity Technology Wireless - 2.4 GHz
Colour Black
Orientation Right-handed
Localisation Europe
Wireless Receiver USB wireless receiver
Movement Detection Technology Optical
Movement Resolution 1200 dpi
Features Scrolling wheel, soft rubber grip
Battery 2 x AA type
OS Required Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista / XP
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Pro Fit Ful...
£23.25
