Kensington Pro Fit Mid-Size Wireless Mouse - Graphite Grey
£20.16
Delivery:
Key features
  • Compact size for travel convenience
  • Clutter-free wireless technology and storable nano receiver
  • Ergonomic right-handed design fits your hand perfectly
  • 2.4 GHz wireless for long range with minimal interference
  • Scroll wheel with middle button and pointer speed quick-select
  • High-definition optical sensor for responsive control and Switchable DPI of 800/1200/1600
  • Extended battery life up to 12 months
  • Built to last with a limited lifetime warranty
  • 2 AAA batteries included
  • Wired / Wireless: Wireless
  • Colour: Graphite grey
  • Compatibility: PC
Product codes
Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
Product Description Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - graphite grey
Device Type Mouse
Connectivity Technology Wireless - 2.4 GHz
Colour Graphite grey
Orientation Right-handed
Wireless Receiver USB wireless receiver
Movement Detection Technology Optical
Buttons Qty 5
Movement Resolution 1600 dpi
Performance Realtime sensitivity switching 800/1200/1600 dpi
Features Scrolling wheel, battery indicator, on/off power switch, Nano wireless receiver, wireless receiver slot, navigation wheel, DPI switch
Battery AAA type
OS Required Apple MacOS X 10.8, Apple MacOS X 10.9, Microsoft Windows XP / Vista / 7 / 8 / 10, Apple MacOS X 10.11, Apple MacOS X 10.10 or later, Apple macOS 10.12 Sierra, Google Chrome OS 44 or later, Apple MacOS X 10.13 or later
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Pro Fit Mid...
£20.16
