We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
Product Description | Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - Ruby Red | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Ruby Red | Orientation | Right-handed | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Movement Resolution | 1750 dpi | Features | Scrolling wheel, Nano wireless receiver | Battery | 2 x AAA type | Manufacturer Warranty | 2-year warranty |
General | |
Colour | Ruby Red |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | Plug and Play |
Battery | |
Type | AAA type |
Installed Qty | 2 |
Run Time (Up To) | 1 year |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
