Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
Product Description | Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - sapphire blue | Device Type | Mouse | Connectivity Technology | Wireless - 2.4 GHz | Colour | Sapphire blue | Orientation | Right-handed | Wireless Receiver | USB wireless receiver | Movement Detection Technology | Optical | Movement Resolution | 1750 dpi | Features | Scrolling wheel, Nano wireless receiver | Battery | 2 x AAA type | Manufacturer Warranty | 2-year warranty |
General | |
Input Device | |
Connectivity Technology | Wireless |
Interface | 2.4 GHz |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | Plug and Play |
Battery | |
Type | AAA type |
Installed Qty | 2 |
Run Time (Up To) | 1 year |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
