Kensington Pro Fit Mid-Size Wireless Mouse
£20.16
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Back and forward web browser navigation reduces time required to complete web browser tasks
  • Ergonomic mid-size design matches natural hand curvature maximising comfort during prolonged use
  • Clickable scroll wheel ideal for speeding through documents
  • Extended battery life up to 12 months
  • High definition optical sensor (800/1200/1600 dpi) delivers smooth cursor control and precise tracking
  • Nano Wireless USB reciever stores inside mouse battery compartment when travelling, ideal for mobile professionals
  • Low battery indicator, to show when batteries need to be replaced
  • Professional black and blue corporate finish complements Pro Fit keyboards
  • On/off switch to conserve battery life
  • PC and Mac compatible
  • Reliable Plug & Play operation with USB connection
  • Requires 2 x AAA batteries (included)
  • Soft rubber panels and contoured buttons maintain comfort and grip
  • Wired / Wireless: Wireless
  • Colour: Black
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
Performance, comfort and reliability are critical in any office environment, the Pro Fit Wired Mid-Size Mouse delivers this every working day. The full-size right-handed ergonomic design makes it ideal for smaller hands. Conveniently located browser navigation buttons and scroll wheel help users complete tasks quicker. Plug and Play wired USB avoids setup pains.
Product Description Kensington Pro Fit Mid-Size - mouse - 2.4 GHz - black
Device Type Mouse
Connectivity Technology Wireless - 2.4 GHz
Colour Black
Orientation Right-handed
Wireless Receiver USB wireless receiver
Movement Detection Technology Optical
Movement Resolution 1750 dpi
Features Scrolling wheel
Battery 2 x AAA type
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Pro Fit Mid...
£20.16
