Kensington Pro Fit Retractable Mobile Mouse
£15.36
Delivery:
Standard: 1-3 working days
Key features
  • Advanced Blue Optical sensor tracks on more surfaces than standard optical (1000dpi)
  • Clickable scroll wheel is ideal for speeding through documents
  • Compatible with Windows XP, Windows Vista , Mac OS X *
  • Designed for durability withstanding everyday drops and spills
  • Professional black and blue corporate finish complements Pro Fit keyboards
  • Reliable Plug & Play operation with USB connection
  • Retractable USB cable stores inside mouse when not in use
  • Wired 76cm cable for battery free, reliable operation
  • Sculpted side panels with soft rubber panels and contoured buttons maintain comfort and grip
Product codes
The Pro Fit range delivers performance and comfort that business users require, day after day, without any fuss. Designed specifically for the business professional the Pro Fit range is the perfect step up from entry level input devices delivering perfomance that can be relied upon.
Kensington Pro Fit Retractable Mobile - mouse - USB - black
Mouse
Wired - USB
Europe
Movement Detection Technology
Optical
Retractable cable
1 x USB cable - integrated
Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Pro Fit Ret...
£15.36
