Kensington Pro Fit Retractable Mobile Mouse
£15.15
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Advanced Blue Optical sensor tracks on more surfaces than standard optical (1000dpi)
  • Clickable scroll wheel is ideal for speeding through documents
  • Compatible with Windows XP, Windows Vista , Mac OS X *
  • Designed for durability withstanding everyday drops and spills
  • Professional black and blue corporate finish complements Pro Fit keyboards
  • Reliable Plug & Play operation with USB connection
  • Wired / Wireless: Wired
  • Colour: Black
  • Compatibility: Mac, PC
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £18.64
Save £1.50
The Pro Fit range delivers performance and comfort that business users require, day after day, without any fuss. Designed specifically for the business professional the Pro Fit range is the perfect step up from entry level input devices delivering perfomance that can be relied upon.
Product Description Kensington Pro Fit Retractable Mobile - mouse - USB - black
Device Type Mouse
Connectivity Technology Wired - USB
Colour Black
Dimensions (WxDxH) 5.4 cm x 9 cm x 3.5 cm
Weight 130 g
Localisation Europe
Movement Detection Technology Optical
Buttons Qty 3
Movement Resolution 1000 dpi
Features Retractable cable
Cables Included 1 x USB cable - integrated
OS Required Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Pro Fit Ret...
£15.15
