The Pro Fit range delivers performance and comfort that business users require, day after day, without any fuss. Designed specifically for the business professional the Pro Fit range is the perfect step up from entry level input devices delivering perfomance that can be relied upon.
Product Description | Kensington Pro Fit Mid-Size - mouse - USB | Device Type | Mouse | Connectivity Technology | Wired - USB | Orientation | Right-handed | Localisation | Europe | Features | Spill-proof | OS Required | Microsoft Windows Vista / XP / 7 | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 5-year warranty |
General | |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Compliant Standards | Plug and Play |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
