Kensington Pro Fit Wired Mid-Size Mouse
£17.95
Delivery:
Standard: 1-3 working days
Key features
  • Clickable scroll wheel is ideal for speeding through documents
  • PC and Mac compatible
  • Compatible with Windows 7, Windows Vista , Windows XP
  • High definition optical sensor delivers smooth cursor control and precise tracking (1000 dpi)
  • Reliable Plug & Play operation with USB connection
  • Professional black and blue corporate finish complements Pro Fit keyboards
  • Sculpted side panels with soft rubber panels and contoured buttons maintain comfort and grip
  • Dedicated, thumb controlled, back and forward web browser navigation reduces time required to comlpete web browser tasks
  • Ergonomic design matches natural hand curvature maximising comfort during prolonged use
  • Wired / Wireless: Wired
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
The Pro Fit range delivers performance and comfort that business users require, day after day, without any fuss. Designed specifically for the business professional the Pro Fit range is the perfect step up from entry level input devices delivering perfomance that can be relied upon.
Product Description Kensington Pro Fit Mid-Size - mouse - USB
Device Type Mouse
Connectivity Technology Wired - USB
Orientation Right-handed
Localisation Europe
Features Spill-proof
OS Required Microsoft Windows Vista / XP / 7
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Pro Fit Wir...
£17.95
