Kensington SD4700P Universal USB-C Dock
£184.10
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Plug & Play: DisplayLink driver installation required
  • Maximum resolution supported: Single monitor - 2560 x 1600 @ 60Hz and Dual monitors - 2048 x 1152 @ 30Hz
  • No of monitors supported: 2
  • Type: Docking
  • Stock Status: In Stock
Product codes
Supporting the advanced USB-C connections, and legacy computers with USB 3.0 ports, the SD4700P Universal USB-C and USB 3.0 Docking Station is the ideal docking solution for evolving computer environments. Engineered using stable technology, the SD4700P provides compatibility that just works. The SD4700P extends the life of your technology investments and is easy and painless to setup.
Product Description Kensington SD4700P USB-C and USB 3.0 Dock - docking station - HDMI, DP
Product Type Docking station
Docking Interface USB-C / USB 3.0
Video Interfaces HDMI, DP
Dimensions (WxDxH) 20 cm x 9.12 cm x 3.05 cm
Weight 1.13 kg
Colour Black
Localisation Europe
Networking Gigabit Ethernet
Power Power adapter 135 Watt AC 120/230 V / DC 20 V (50/60 Hz)
Pricing Type Brown Box
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SD4700P Uni...
£184.10
