Kensington Security Locking System
£34.09
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 3M VHB industrial adhesive tape on stick on anchor for non-Kensington Security Slot equipped peripherals - 1 square inch (645mm x 645mm)
  • Anchor plate secures equipment without a Kensington Security Slot
  • Cable trap secures a wired keyboard and mouse
  • Custom keyed options available ideal for offices, labs and libraries*
  • Everything you need to secure a desktop computer, two peripherals and a wired keyboard and mouse
  • Hidden Pin technology ensures tubular locks cannot be picked offering the highest level of security
  • Device Type: Laptop
  • Type: Security
  • Device Screen Size: [N/A]
  • Stock Status: In Stock
Product codes
All Kensington locks are built to exacting engineering standards. This lock is rated as Safe Pro, a rating awarded to Kensington Security Locks that are tested under stringent test conditions by third party testing agencies for their ability to withstand attacks.
We provide two keys with each standard lock. Each key is stamped with a unique code. Register your code online and well be able to send you a replacement key.
Our business is protecting yours
Kensington locks are made with high-carbon steel cables and tested under rigorous real-world conditions to resist lock-picking, corrosion, tampering and extreme environments. Our locks set the industry standards, and continue to exceed them.
Master keyed solutions available
Master keyed solutions allow you to tailor the physical security of equipment to specific business needs. Regulate access with a set of locks that can be opened by a master key. Offer employees unique, individual keys to their own locks while you keep a mast.
Product Description Kensington Desktop and Peripherals Locking Kit system security kit
Product Type System security kit
Product Material Carbon steel
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Security Lo...
£34.09
