Kensington Sit Stand Workstation Dual Arm
£56.56
Delivery:
Key features
  • Easy installation that takes only a few minutes
  • Adjustable dual mounts allows you to slide the monitors left and right along both sides of the arm for a better fit
  • Ideal with monitors featuring either the 75mm or 100mm VESA configuration
Product codes
Please Note: This is only the Dual Monitor Arm, not the full Workstation. This needs to be purchased with KW55792WW - Quicklinx BWGP
Take productivity to a professional level by adding a dual monitor arm to your SmartFit Sit/Stand Workstation. Studies have shown using two monitors can have a dramatic effect on workflow. With dual monitors on your workstation, not only are you getting the ergonomic and health benefits of standing while you work, youre also getting a lot more work done. Our patented SmartFit System lets you find your personal comfort color to set the monitors at the ideal viewing height, plus the arm installs quickly to your Sit/Stand workstation and is VESA-compatible for monitor screens up to 24 inches.
Kensington - mounting component
Mounting component
Mounting Components
Dual arm
Recommended Use
2 monitors
Recommended Display Size
Up to 24"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10.2 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Sit Stand W...
£56.56
