Kensington Slim MicroSaver Security Kit
£35.74
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Carbon steel cable is cut-resistant and anchors to desk, table or any fixed structure
  • Hidden Pin technology ensures tubular lock cannot be picked
  • T-Bar Locking Technology attaches to the Kensington Security Slot found on most laptops
  • Register & Retrieve program allows you to order replacement keys
  • Trust the industry standard that been locking devices for more than 20 years to protect your valuable laptop and the sensitive information thats on it
  • Two keys supplied
  • Type: Security Kit
  • Stock Status: In Stock
Product codes
Documents
The MicroSaver lock head features the patented T-bar locking mechanism. The T-bar provides a tight fit with the Kensington Security Slot. A rubber bumper ensures a snug fit between the lock and the security slot and protects your hardware. A further deterrent is the tamper evident feature. When a Kensington MicroSaver lock is tampered with, it locks itself down and can even trap foreign keys.
All Kensington locks are built to exacting engineering standards. This lock is rated as Safe Pro, a rating awarded to Kensington Security Locks that are tested under stringent test conditions by third party testing agencies for their ability to withstand attacks.
We provide two keys with each standard lock. Each key is stamped with a unique code. Register your code online and well be able to send you a replacement key.
Our business is protecting yours
Kensington locks are made with high-carbon steel cables and tested under rigorous real-world conditions to resist lock-picking, corro.
Product Description Kensington MicroSaver security cable lock
Product Type Security cable lock
Package Content Security cable
Length 1.8 m
Features Key lock, T- bar lock
Package Type Retail
Resources
The following resources are available for the Kensington Slim MicroSaver Security Kit
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Slim MicroS...
£35.74
