Kensington Slimblade Trackball
£93.94
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Ambidextrous design for left or right-handed users
  • Ambidextrous design ideal for both right-handed and left-handed users
  • Free TrackballWorks software allows you to customize buttons, cursor and scrolling speeds
  • Laser tracking technology delivers superior precision for increased productivity
  • PC and Mac compatible
  • Plug & Play installation
  • Recommended Use: Office
  • Type: Trackball
  • Wired / Wireless: Wired
  • Colour: Metalic silver, Ruby Red
  • Compatibility: Mac, PC
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £97.43
Save £1.50
Kensington TrackballWorks
idea: Your trackball, your rules.
Download Kensington TrackballWorks software to customise the functions of each of the buttons found on this Kensington trackball. The result is a more productive and truly personalized computing experience. Set your preferred functions or keyboard shortcuts for each trackball button or combination of buttons, adjust the pointer speed and acceleration and do so much more. Best of all, by allowing you to personalise your trackball experience, TrackballWorks makes your trackball work the way you do. TrackballWorks is compatible with the latest operating system versions including Windows 7, Windows Vista , Windows XP and Mac OS.
Product Description Kensington SlimBlade Trackball - trackball - USB - Ruby Red, metalic silver
Device Type Trackball
Connectivity Technology Wired - USB
Colour Ruby Red, metalic silver
Orientation Right and left-handed
Localisation Europe
Movement Detection Technology Laser / optical
Buttons Qty 4
Cable Length 1.5 m
Cables Included 1 x USB cable - integrated
OS Required Microsoft Windows 7 or later, Apple MacOS X 10.8 or later
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Slimblade T...
£93.94
