Kensington SlimBlade Wireless Laser Mouse
£46.35
Delivery:
Standard: 1-3 working days
Key features
  • 4 way tilt scroll wheel is ideal for speeding through documents and managing data
  • Laser sensor gives you precise control on more surfaces
  • Nano Wireless USB reciever stores inside mouse battery compartment when travelling
  • Requires 2 x AAA batteries (included)
  • Rubber side panels maintain comfort and grip
  • On/Off switch helps prevent accidental battery drain
  • Professional high gloss black finish
  • Thin profile, ultra portable design makes mobility easy
  • PC and Mac compatible
  • Wired / Wireless: Wireless
  • Compatibility: PC
  • Stock Status: In Stock
Product codes
This precision laser mouse travels well and is ready when you are. The Kensington SlimBlade Wireless Laser Mouse offers a laser sensor for precise control on more surfaces. A storable nano receiver offers wireless freedom and is always ready to work. Plus the thin profile, ultra portable design makes mobility easy.
Product Description Kensington SlimBlade with Nano Receiver - mouse - 2.4 GHz
Device Type Mouse
Connectivity Technology Wireless - 2.4 GHz
Localisation Europe
Wireless Receiver USB wireless receiver
Movement Detection Technology Laser
Features Scrolling wheel (4-way), battery indicator, on/off power switch
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SlimBlade W...
£46.35
