Kensington SmartFit Dual Monitor Arm
£193.06
Delivery:
Key features
  • Assembles to the edge of the desktop via grommet clamp in just minutes
  • Cable management system helps neatly route cords for a clutter-free desktop
  • SmartFit System allows you to find your personal comfort color within 4 height regions for optimal ergonomics
  • Monitors attach via 75mm or 100mm VESA-compatible mounts
Product codes
With more than 20 years of expertise creating professional-level ergonomic solutions, Kensington has created the SmartFit Dual Monitor Arm Mount. It allows you to add a second display to your desktop, which studies have shown can have a significant impact on daily productivity. With two fully adjustable arms that hold up to 24 monitors, you can use our patented SmartFit system to find your optimal height setting to reduce neck, back and vision strain. It assembles in minutes, letting you quickly get back to whats important.
Kensington SmartFit Dual Monitor Arm Mount - mounting kit
Mounting kit - desktop
Mounting Components
Desk clamp mount, 2 monitor arms
Adjustments
Height, pan, tilt, lift
Recommended Use
2 LCD displays
Dark grey
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SmartFit Du...
£193.06
