With more than 20 years of expertise creating professional-level ergonomic solutions, Kensington has created the SmartFit Dual Monitor Arm Mount. It allows you to add a second display to your desktop, which studies have shown can have a significant impact on daily productivity. With two fully adjustable arms that hold up to 24 monitors, you can use our patented SmartFit system to find your optimal height setting to reduce neck, back and vision strain. It assembles in minutes, letting you quickly get back to whats important.
Product Description | Kensington SmartFit Dual Monitor Arm Mount - mounting kit | Product Type | Mounting kit - desktop | Mounting Components | Desk clamp mount, 2 monitor arms | Adjustments | Height, pan, tilt, lift | Recommended Use | 2 LCD displays | Colour | Dark grey | Manufacturer Warranty | 2-year warranty |
General | |
AV Furniture | |
Type | Mounting kit |
Placing / Mounting | Desktop |
Cable Management | Integrated cable management |
Adjustable Feet | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
