Kensington SmartFit Extended Monitor Arm
£105.36
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Pre-assembled for quick and easy installation
  • Assembles in minutes with clamp fixing options
  • Cable management system reduces desktop clutter
  • Arm is fully height and length adjustable and folds flat against a panel
  • Stock Status: In Stock
Product codes
One size doesn't fit all. When it comes to comfort, fit is everything.
Complying with ergonomic standards doesnt have to be a pain. The Kensington SmartFit system eliminates the complication, confusion and high cost of giving your employees safe, comfortable, ergonomic workstations. Years of research from the US Army revealed a direct correlation between hand size and body measurements. The result is a simple colour-coding system that allows users to adjust for the perfect fit in seconds, every time, leaving you to deal with more important projects.
SmartFit demystifies ergonomics for individuals making it easy to install and customise their workspace accessories to their ergonomic comfort requirements.
Every SmartFit product includes a hand chart in the box. This indicates the specific SmartFit colour setting that will deliver optimum ergonomic comfort for the user.
A small investment in workplace ergonomics can generate significant rewards in productivity by reducing fatigue, chronic injuries, absenteeism and even legal costs.chronic injuries, absenteeism and even legal costs.
Product Description Kensington Column Mount Extended Monitor Arm with SmartFit System - monitor arm
Product Type Monitor arm
Localisation United States
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SmartFit Ex...
£105.36
