Kensington SmartFit Laptop Riser - Notebook stand - 15.6" -
£54.38
Delivery:
Key features
  • 4 available height settings
  • Anti-skid pads keep laptop firmly in place
  • Cable management under the laptop platform helps neatly route cords
  • Kensington Security Slot available on both right and left legs
  • SmartFit System allows you to find your personal comfort color for optimal ergonomics
  • Zero footprint mounting allows you to mount a compatible Kensington universal dock under the laptop platform
Product codes
When you need to lift your laptop up to eye level, theres no better ergonomic solution than the SmartFit Laptop Riser. Kensington has been a leader in ergonomics for more than 20 years and the laptop riser features the SmartFit System, which allows you to find your personal height setting for optimal comfort to reduce neck and back strain while you work. It also utilizes Zero Footprint mounting so you can mount a compatible Kensington universal dock underneath the laptop platform, keeping your desktop less cluttered.
Product Description Kensington SmartFit Laptop Riser notebook stand
Product Type Notebook stand
Colour Black
Notebook Compatibility 15.6"
Features Adjustable height, integrated cable management, anti-skid grip, SmartFit, kensington security slot, Zero Footprint Mounting
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SmartFit La...
£54.38
