Kensington SmartFit Monitor Stand Plus - Grey
£46.06
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Accessories and papers can be stored under stand to save desk space
  • Height adjusts to 1 of 3 vertical settings without tools
  • Determine your SmartFit comfort colour, then set monitor height to match by snapping 1 or 2 risers into place
  • Universal platform design fits any monitor up to 21" and 36kgs
  • Stand positions monitor in line with your eyes to help reduce eye and neck strain
  • Stylish construction and color complement any decor
  • SmartFit(TM) system lets you adjust monitor height to your personal requirements
  • Stock Status: In Stock
Product codes
Monitor Stand Plus with the SmartFit system adjusts monitor height to your optimal viewing angle to help to reduce eye and neck strain. Expands usable desk space by allowing storage underneath platform.
Product Description Kensington SmartFit Plus - stand
Product Type Stand - desktop
Dimensions (WxDxH) 39.4 cm x 30.5 cm x 14 cm
Adjustments Height
Recommended Use LCD display
Recommended Display Size 21"
Max Load Weight 36.3 kg
Colour Grey, black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SmartFit Mo...
£46.06
