Kensington SmartFit Mouse Pad
£19.60
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Anti-microbial surface resists stains and odours for a worry-free experience
  • Gel wrist pad provides a cool, comfortable surface that conforms to your wrist and relieves pressure points
  • Height adjustable inserts are set to your colour and help set your wrist at the correct angle for comfortable clicking and scrolling
  • Non-skid base provides stability and keeps the wrist rest firmly in place
  • SmartFit System lets you measure, adjust and fit the mouse pad to find your ideal comfort colour setting
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £23.09
Save £1.50
Resting your wrist on a soft, cushioned surface while you click and scroll with your mouse may seem comfortable, but improper positioning can cause discomfort over time. The SmartFit mouse pad not only provides a comfortable gel support, it also allows you to customize and adjust the height of the rest so your wrist is at a neutral angle. An anti-microbial surface resists stains and odors and the non-skid base provides great stability.
Product Description Kensington SmartFit mouse pad
Product Type Mouse pad
Colour Black
Localisation Europe
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SmartFit Mo...
£19.60
