Kensington SmartFit Sit/Stand Workstation
£350.77
Delivery:
Key features
  • Cable management channel routs accessory cords to keep workstation uncluttered
  • Articulating arm has four pivot points so you can easily move the workstation up and down and side to side
  • Height adjustable so you can set the monitor and the keyboard platform independently for the ideal viewing and typing settings
  • Secondary platform provides a space-saving area for additional accessories
  • Pneumatic lift lets you quickly and easily transition from sitting to standing
  • SmartFit System allows you to measure, adjust and fit the workstations articulating arm to your ideal comfort color setting
  • Reinforced mounting clamp attaches quickly to the desktop
Product codes
The SmartFit Sit/Stand Workstation lets you easily convert your traditional desk it into a standing workspace, giving you ergonomic and health benefits. It installs quickly and requires minimal changes to your current setup. Our patented SmartFit System lets you find your personal comfort color and set the workstation to the ideal height for your monitor and keyboard/mouse platform. A pneumatic lift and articulating arm let you quickly transition from sitting to standing and adjust the unit from side to side.
Product Description Kensington SmartFit Sit/Stand Workstation - mounting kit
Product Type Mounting kit - desktop
Mounting Components Sit-stand arm, mouse platform, desk clamp pole, keyboard platform
Adjustments Height, pan, tilt, lift
Recommended Use LCD display / keyboard / mouse
Max Load Weight 10 kg
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SmartFit Si...
£350.77
