Kensington SP10 15.6" Classic Sleeve
£11.02
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Detachable padded shoulder strap allows you to turn the sleeve into a portable case
  • Extremely soft fleece lining protects your device from scratches
  • High density neoprene sleeve protects and cushions your laptop or ultrabook
  • Pockets on either side are ideal for storing chargers and cables while travelling
  • Reinforced carry handle allows you to easily transport your device while reducing the worry that it might get dropped or damaged
  • Stock Status: In Stock
Product codes
A classic notebook computer sleeve for when you're on the move. The Kensington SP10 15.6" Sleeve protects your notebook with a durable nylon exterior that's tough enough to travel with you. Plus, interior and exterior storage compartments have plenty of room for accessories and important files. All the functionality you need at a great value.
Product Description Kensington SP10 15.6" Classic Sleeve notebook carrying case
Product Type Notebook carrying case
Colour Black
Product Material Nylon
Dimensions (WxDxH) 38.1 cm x 6.4 cm x 32.4 cm
Weight 408 g
Notebook Compatibility 15.6"
Features Padded
Carrying Strap Shoulder carrying strap
Localisation Europe
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SP10 15.6"...
£11.02
