Kensington SP12 12" Neoprene Notebook Carrying Sleeve
£20.64
Delivery:
Standard: 1-3 working days
Key features
  • Detachable padded shoulder strap allows you to turn the sleeve into a portable case
  • Extremely soft fleece lining protects your device from scratches
  • High density neoprene sleeve protects and cushions your ultrabook, tablet or e-reader
  • Reinforced carry handle allows you to easily transport your device while reducing the worry that it might get dropped or damaged
  • Zipper front storage compartment is ideal for storing chargers and cables while travelling
  • Device Type: Laptop, Tablet
  • Stock Status: In Stock
Product codes
The Kensington SP12 12" Neoprene Sleeve features a neoprene exterior, which provides protection for your laptop or netbook, and soft comfortable carrying handles, while front and inside pockets provide plenty of room for accessories and important files. All the functionality you need at a great value.
Product Description Kensington SP12 12" Neoprene Sleeve notebook carrying case
Product Type Notebook carrying case
Colour Black
Product Material Neoprene
Dimensions (WxDxH) 31.8 cm x 6.35 cm x 33.7 cm
Weight 340 g
Notebook Compatibility 12"
Features Padded, inside pocket, shoulder strap loop
Carrying Strap Hand strap, shoulder carrying strap
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SP12 12" Ne...
£20.64
