Kensington SP17 Classic Sleeve 17"
£17.77
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Detachable padded shoulder strap allows you to turn the sleeve into a portable case
  • Pockets on either side are ideal for storing chargers and cables while travelling
  • Extremely soft fleece lining protects your device from scratches
  • High density neoprene sleeve protects and cushions your laptop or ultrabook
  • Reinforced carry handle allows you to easily transport your device while reducing the worry that it might get dropped or damaged
  • Stock Status: In Stock
Product codes
A classic notebook computer sleeve for when you're on the move. The Kensington SP17 17" Classic Sleeve protects your notebook with a durable polyester exterior that's tough enough to travel with you. Plus, interior and exterior storage compartments have plenty of room for accessories and important files. All the functionality you need at a great value.
Product Description Kensington SP17 17" Classic Sleeve notebook carrying case
Product Type Notebook carrying case
Colour Black
Product Material Polyester
Dimensions (WxDxH) 440 mm x 70 mm x 340 mm
Weight 480 g
Notebook Compatibility 17"
Features Padded, padded shoulder strap
Carrying Strap Shoulder carrying strap
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington SP17 Classi...
£17.77
