Kensington Spin2 Monitor Stand - Black
£26.86
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Patented 360-degree spinning carousel organizes common desktop accessories
  • Platform fits most widescreen monitors up 18kg
  • Small footprint helps conserve valuable desktop space
  • SmartFit System lets you adjust monitor height to your personal comfort colour
  • Stand positions monitor in line with your eyes to help reduce eye and neck strain
  • Stock Status: In Stock
Product codes
Let the ergonomics innovator with long years of expertise maximize your desktop space with this professional monitor stand. The patented, spinning multi-compartment storage area underneath the platform provides easy access to your most-used desktop tools and accessories. Measure, adjust and fit yourself with Kensingtons patented SmartFit System so you can customize your monitor height using the color-coded personal comfort system.
Product Description Kensington SmartFit Spin2 - stand
Product Type Stand
Rotation 360°
Adjustments Height
Recommended Use Monitor
Max Load Weight 18.1 kg
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Spin2 Monit...
£26.86
