Kensington UA0000E USB 3.0 Ethernet Adapter - Black
£21.55
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Add Ethernet port for wired Internet connection
  • Powered via USB and connects to USB port of your laptop and provides an RJ-45 connector that supports 10/100/1000 BASE-T performance
  • Requires WiFi connection to download driver
  • Simple plug & play operation after one-time driver installation
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Compatibility: Mac, PC
  • Type: Network adapter
  • Stock Status: In Stock
Product codes
Many newer laptops do not come with an Ethernet port, leaving users only WiFi to get connected to the Internet. The UA0000E USB 3.0 Ethernet Adapter provides a wired connectivity option with lightning fast transfer speeds where wireless access isnt available or if you have a broken internal network card. The USB 3.0 Ethernet adapter simply plugs into an available port on your laptop or desktop computer and supports 10/100/1000 BASE-T performance. The adapter is compatible with systems running Windows 8.1/8/7/Vista/XP, as well as Mac OS X 10.6 and later.
Product Description Kensington UA0000E - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type SuperSpeed USB 3.0
Ports Gigabit Ethernet x 1
Dimensions (WxDxH) 7.6 cm x 2.4 cm x 1.5 cm
Weight 26 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1 Gbps
Compliant Standards USB 2.0, USB 3.0
Colour Black
System Requirements Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington UA0000E USB...
£21.55
