Kensington UA3000E USB 3.0 Ethernet Adapter & 3-Port Hub...
Kensington UA3000E USB 3.0 Ethernet Adapter & 3-Port Hub - Black
£48.12
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Add Ethernet port for wired Internet connection
  • Requires WiFi connection to download driver
  • Connects to USB port of your laptop and provides an RJ-45 connector that supports 10/100/1000 BASE-T performance
  • Simple plug & play operation after one-time driver installation
Product codes
Many newer laptops do not come with an Ethernet port, leaving users only WiFi to get connected to the Internet. The UA3000E USB 3.0 Ethernet Adapter & 3-Port Hub provides a wired connectivity option with lightning fast transfer speeds where wireless access isnt available or if you have a broken internal network card. The USB 3.0 Ethernet adapter simply plugs into an available port on your laptop and supports 10/100/1000 BASE-T performance. Also included are three USB 3.0 ports for additional device expansion. The adapter is compatible with systems running Windows 8.1/8/7/Vista/XP, as well as Mac OS X 10.6 and later.
Kensington UA3000E - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet x 1 + USB 3.0 x 3
10.5 cm x 4.5 cm x 2.4 cm
68 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
USB 2.0, USB 3.0
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington UA3000E USB...
£48.12
