Kensington UH4000 USB 3.0 4-Port Hub - Black
Key features
  • Add 4 USB ports for simple device expansion
  • Plug & Play installation with no drivers
Product codes
With USB ports on laptops becoming a precious commodity, an external hub can be the answer to maintaining optimal productivity. The UH4000 USB 3.0 4-Port Hub ensures you can connect all your peripheral desktop accessories so you can perform at your peak. Leveraging USB 3.0 technology, each of the four ports can support lightning fast transfer speeds so you can work more efficiently. And because there are no drivers to download, simply insert the USB cable on the hub into your laptop and you're ready to go.
Kensington UH4000 - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB 3.0
7.55 cm x 3.8 cm x 1.3 cm
34 g
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington UH4000 USB...
