Kensington UH4000C USB 3.0 4-Port Hub & Charger - Black
Key features
  • 3 AMPs are available to fast charge smartphones and/or a tablet when hub is plugged into a wall outlet for external power
  • Add 4 USB ports for simple device expansion
  • Charging ports are compliant with USB BC 1.2 standard and compatible with BC 1.2 devices such as iPad 4th gen, iPad Air and iPad mini (check your device specs)
  • Compatible with systems running Windows 8.1/8/7/Vista/XP and Mac OS X 10.6 or later
  • Plug & Play installation with no driver downloads necessary
  • USB 3.0 for data speeds up to 5 Gbps, which is 10x faster than USB 2.0
Product codes
With USB ports on laptops becoming a precious commodity, an external hub can be the answer to maintaining optimal productivity. The UH4000C USB 3.0 4-Port Hub & Charger ensures you can connect all your peripheral desktop accessories to your laptop, as well as quickly charge your smartphone or tablet. Leveraging USB 3.0 technology, each of the four ports can support lightning fast transfer speeds so you can work more efficiently. The ports also double as chargers, ensuring the battery on your favorite devices never runs out. With 3 AMPs available, you can use any of the ports to provide a fast charge for a tablet and a smartphone, or other combination of low power devices. Because there are no drivers to download, simply insert the USB cable it into your laptop, plug in the power cord, and you're ready to go.
Kensington UH4000C - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB 1.1, USB 2.0, USB 3.0
7.5 cm x 5.1 cm x 1.45 cm
38 g
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Europe
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington UH4000C USB...
