Kensington UH7000C USB 3.0 7-Port Hub & Charger - Black
Key features
  • Plug & Play installation with no driver downloads necessary
  • 4 AMPs are available to fast charge smartphones and/or tablets when hub is plugged into a wall outlet for external power
  • Add 7 USB ports for simple device expansion
Product codes
With USB ports on laptops becoming a precious commodity, an external hub can be the answer to maintaining optimal productivity. The UH7000C USB 3.0 7-port hub & charger ensures you can connect all your peripheral desktop accessories to your laptop, as well as quickly charge your smartphone or tablet. Leveraging USB 3.0 technology, each of the seven ports can support lightning fast transfer speeds so you can work more efficiently. The ports also double as chargers, ensuring the battery on your favorite devices never runs out. With 4 AMPs available, you can use any of the ports to provide a fast charge for up to two tablets, a tablet and a smartphone, or any other combination of low power devices. Because there are no drivers to download, simply insert the USB cable it into your laptop, plug in the power cord, and you're ready to go.
Kensington UH7000C - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x SuperSpeed USB 3.0
USB 1.1, USB 2.0, USB 3.0
10.8 cm x 5.2 cm x 1.7 cm
62 g
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Europe
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington UH7000C USB...
