Kensington Ultra MicroSaver2.0 Keyed Lock
£40.89
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Independently verified and tested for industry-leading standards in torque/pull, foreign implements, lock lifecycle, corrosion, key strength and other environmental conditions
  • Pivot and rotate ball joint provides superior laptop engagement
  • Register & Retrieve program allows you to order replacement keys
  • T-Bar Locking Technology attaches to the Kensington Security Slot found on most laptops and other devices
  • Strong 10mm lock head offers uncompromised security for even the thinnest laptops and devices
  • Patented Hidden Pin Technology provides anti-pick features unique to Kensington
  • Ultra carbon steel cable is extra thick to provide the highest level of cut resistance
Product codes
Engineered to be s small lock for laptops and other devices with no compromises, the MicroSaver 2.0 represents the next generation of laptop security with a cable that's stronger than the standard model. The MicroSaver 2.0 was developed using strict specifications and advanced technologies in a smaller, compact size.
Kensington MicroSaver 2.0 Keyed Ultra Laptop Lock - security cable
Security cable
Silver
Product Material
Carbon steel
T- bar lock, pivot adjustment, cut-resistant, hidden pin, rotatable
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Ultra Micro...
£40.89
