Kensington Universal Case for 10'' Tablets - Black
Key features
  • Silicone 4-Corner Base uses stay straps that come up and over the tablet to hold it in place
  • Lightweight, universal design with contemporary cover that securely holds 9 and 10 tablets
  • Unobstructed access to charging port and front camera
  • Magnetic flap securely closes folio
  • Multi-position stand provides a range of viewing options
  • Soft interior lining protects display from scratches
Product codes
Not all 9-inch and 10-inch tablets are made to the same specifications. A half-inch there or there and your tablet wont fit into a case. Kensington has solved that problem with a universal case that features a contemporary cover design and can hold all the most popular 9-inch and 10-inch tablets. The soft, lightweight case offers secure protection for your device through the Silicone 4-Corner Base, which uses stay straps that come up and over the corners of the tablet. The inside cover has soft lining that prevents the screen from getting scratched or damaged and a magnetic flap keeps the case securely closed. The cover can be opened or folded into an upright or low-angle triangle stand so you can select the ideal position for watching videos, typing emails or web browsing.
Product Description Kensington Universal - flip cover for tablet
Product Type Flip cover for tablet
Screen Size Compatibility 10"
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Universal C...
