Not all 7-inch and 8-inch tablets are made to the same specifications. A half-inch there or there and your tablet wont fit into a case. Kensington has solved that problem with a universal case that features a contemporary cover design and can hold all the most popular 7-inch and 8-inch tablets.* The soft, lightweight case offers secure protection for your device through the Silicone 4-Corner Base, which uses stay straps that come up and over the corners of the tablet. The inside cover has soft lining that prevents the screen from getting scratched or damaged and a magnetic flap keeps the case securely closed. The cover can be opened or folded into an upright or low-angle triangle stand so you can select the ideal position for watching videos, typing emails or web browsing. *Fits most 7 tablets.
