Kensington USB Lock W Cable Guard Rectangular
£40.69
21 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A USB Port Block used with a single USB Port Lock prevents access to adjacent ports with either vertical or horizontal orientation
  • Near universally compatible, they fit into the USB ports of most devices but we strongly recommend asking for a sample to ensure a proper fit
  • If you already have encryption software in place, the added layer of physical security is additional insurance against data theft
  • One USB Cable Guard captures and locks in a USB Cable (for a keyboard or mouse) in a port adjacent to a USB Port Lock
  • Just plug into the USB port and push the button to lock
  • Physically protects valuable data without the complication, installation, maintenance, and upgrade costs of software
Product codes
Reduce the risk of data leakage, data theft and unauthorized uploads with a solution that physically blocks USB ports from unauthorized access. The Kensington USB Port Lock with Cable Guard - Rectangular has the ability to block multiple adjacent ports, one with an active USB device such as keyboard or mouse with one lock, allowing continued secure use of authorized USB devices.
Product Description Kensington USB Port Lock with Cable Guard - Rectangular - USB port blocker
Product Type USB port blocker
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£40.69
