Kensington USB Port Lock With Blockers
£27.02
Delivery:
Standard: 1-3 working days
Key features
  • A USB Port Block used with a single USB Port Lock prevents access to adjacent ports with either vertical or horizontal orientation
  • If you already have encryption software in place, the added layer of physical security is additional insurance against data theft
  • Just plug into the USB port and push the button to lock
  • Physically protects valuable data without the complication, installation, maintenance, and upgrade costs of software
  • Near universally compatible, they fit into the USB ports of most devices but we strongly recommend asking for a sample to ensure a proper fit
  • One USB Port Block blocks a port adjacent to a USB Port Lock
  • Stock Status: In Stock
Product codes
Reduce the risk of data leakage, data theft and unauthorized uploads with a solution that physically blocks USB ports from unauthorized access. The Kensington USB Port Lock with Blockers has the ability to block multiple adjacent ports with one lock and allow continued secure use of authorized USB devices.
Product Description Kensington USB Port Lock with Blockers USB port blocker
Product Type USB port blocker
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington USB Port Lo...
£27.02
