Kensington VESA Mount Plate for Kensington SD3600 USB 3.0 Dua...
Kensington VESA Mount Plate for Kensington SD3600 USB 3.0 Dual-Dock
£6.62
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Adjustable during installation to place the dock at your desired height setting
  • Allows you to mount a docking station, like the SD3600, on the back of your monitor
  • Compatible with monitors featuring either 75mm or 100mm VESA layout
Product codes
If youre incorporating a Kensington Docking Station into your system, such as the SD3600, but you have limited desktop space, the Docking Station Mounting Plate is the ideal complement. It allows you to mount the dock on the back of your VESA-compatible monitor even if its attached to a monitor arm. The mounting plate also has special slots that let you adjust the placement of the dock to your preferred location.
Kensington - mounting component
Mounting component
Mounting Components
Mounting plate
Recommended Use
Docking station
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington VESA Mount...
£6.62
