Kensington Virtuoso Stylus and Pen for Tablets - Black
£17.28
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Compatible with tablets and smartphones
  • Pen cap fits securely over stylus
  • Soft tip provides comfort and control and wont scratch your screen
  • Full length KeySellingPoints for familiar grip and feel
  • Other side of stylus features a ballpoint pen with cap
  • Chrome pocket clip
  • Available in a range of colours
  • Allows you to create and annotate
  • Stock Status: Clearance
Product codes
Tablets are great fun to useuntil you realise that every time you touch one to navigate or type, youre just adding another smudge to the tablet screen. The fact is, no matter how clean your hands are they naturally emit oils. And oils and tablet screens dont get along. Before you know it, your screen is covered with grease and oils that not only make it difficult to see the screen but also attract dirt and grime that can permanently scratch and damage your tablet screen.
Fortunately theres a simple solution that not only keeps your screen clean, but also adds accuracy and comfort. Its the Kensington Stylus. The responsive and sensitive soft tip was specially designed to work on delicate tablet screens and smartphones. It glides more smoothly across your tablet screen than any finger and provides comfort and control whether youre creating art, annotating files or just replying to an email. The soft tip will never scratch your tablet screen. And most important it keeps your fingers off the screen so your screen stays nice and clean.
Of course, there are still times when you have to take notes, sign documents or fill out paper forms. The Virtuoso has you covered there as well because the other end contains a ballpoint pen. And the cap fits snugly over the stylus so losing it is not an option.
The Virtuoso Stylus & Pen is available in a rainbow of colors that not only look great on their own, but also mix and match perfectly with the Kensington KeyFolio Exact and Comercio Folio. So go ahead and get the one accessory that will not only preserve your screen but also make using your tablet more comfortable: a Kensington Stylus.
Product Description Kensington Virtuoso - stylus / ballpen
Product Type Stylus / ballpen
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Virtuoso St...
£17.28
