Kensington VM1000 Mini Display Port to VGA Adapter
£19.24
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Plug & Play installation
  • Simple Mini DisplayPort to VGA connection
  • Supports 1920 x 1200 resolution
  • Stock Status: In Stock
Product codes
When you need to put whats on your laptop screen on a monitor or a projector, theres no easier way than with the VM1000 Video Adapter. It plugs into Mini DisplayPort commonly found on laptops and then runs to the VGA port on a monitor or projector. The adapter supports full HD resolution so you get a crystal clear picture and offers Plug & Play installation so youre up and running in no time.
Product Description Kensington VM1000 Mini DisplayPort to VGA Adapter - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort input - Mini DisplayPort
Dimensions (WxDxH) 2.5 cm x 1.3 cm x 27.9 cm
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington VM1000 Mini...
£19.24
