Kensington Wireless Presenter with Green Laser
£73.48
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Backlit button controls move slides forward/back, black out screen and activate the green laser pointer
  • Comfortable grip with special contours for the hand
  • Cursor control joystick lets you use the presenter like a mouse, moving cursor up/down and left/right
  • Green laser pointer is 10x brighter than a red laser
  • Extended 150-foot wireless range to roam the room
  • Internal storage for wireless USB receiver so it wont get lost
Product codes
Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter with Green Laser Pointer & Cursor Control. Sometimes pointing just isnt enough. With a simple flick of a switch, you toggle between presentation and cursor control modes. The wireless 2.4GHz receiver stores conveniently inside the remote, and since its uniquely paired, you dont have to worry about device interference. Make your point with a green laser thats 10 times brighter than standard red lasers, ideal for bigger rooms and LED/LCD screens.
Kensington Presenter Expert Green Laser with Cursor Control - presentation remote control
Presentation remote control
Enclosure Colour
Europe
Radio
Max Operating Distance
50 m
Pointing device battery
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Kensington Wireless Pr...
£73.48
